Spec me an "N" series ADSL2+ wireless Router...
8 Jun 2006
Hertfordshire
Hi Guys
My current DG834GT v3 is on it's last legs!
I have an "N" series wireless card in my new laptop so I may as well go for something to compliment that..
Currently with "Be There" I get 12meg down solid but that was due to 3rd party firmware on my current router as I think a was getting 9.5meg before..
Anyway can anyone recommend one from the OcUK shop or just recommend a good solid router with good signal coverage?
Many thanks ;)
These are supposed to be alright, Broadcom chipset so should get good sync speeds with Be. A DG834GT is probably still the better choice for tweaking the most out of your connection though.
Yeah I thought that. will have a look though thanks
Draytek 2820, use them in work and you get a free draft n usb adapter at the moment too.
Heard good things about the Draytek from guys at work too cheers
