Just looking for some ideas on this folks,
I am trying to get my head around a project for work to try and improve the way some technical reports are written and produced, I can get my head around how I would do most of it, one thing I am missing is what format to use to present the data from the back end into a report that can be presented to the client.
At the moment we type them in word and have a template set up. Now *.DOC is obviously a no go, because its a closed format. Now I did consider HTML but that is designed to be displayed on a screen rather than printed and I need to control how it falls on the page (i.e. a numbered bullet point and its associated image all one one page not spread across 2) and also page numbering (which needs to be integrated with other pages.... so if I had a 5 page report, it might be added to 10 pages of test data. So the report would theen need numbering 11/15 to 15/15 not 1/5 to 5/5 as it would if you printed a HTML file.
So my question is simply, is there anything out there, such as a page layout 'language' that is designed for print and is easily enough to spit out from a bit of code?
Any ideas welcome
Any ideas welcome
. They get the choice of Printed and bound A4, or a PDF so they can print it themselves A4. Or both if they so desire
