Hi Guys,
I would appreciate some help in putting together an upgrade for my new (Low/Mid end) gaming system, I just need it to play games at reasonable speeds. I'm really rusty with my performance knowledge and the current component market, The last time I looked was in 2007 when I built my current system...
CPU: AMD Athlon 64 2X 3600 Brisbane Core 65nm @ 1.9GHz (AM2)
MB: Gigabyte M61SME-S2L (AM2)
RAM: OCZ Gold 2GB (2x1GB) DDR2 PC2-6400 (CL 5, tRCD 5, tRP 5, tRAS 15, tRC 23)
GPU Gainward Nvidia 7800GS
Its a real Dinobot!
Winging its way to me in the post are the following parts that I will be including in the system...
OCZ ModXStream Pro 600w (this was one I already had. had to RMA it so the replacement should be coming soon)
1x Radeon HD5770 (bought from a member here)
My first question is, how badly will the system I've already got throttle the HD5770? I really need some perspective on this, I've got a feeling the system I've got is a bit of a cougar now and putting the 5770 in there will be beyond a Mrs Robinson scenario.
to stop this kind of disgusting copulation from happening it seems to me that I have two options.
I could lob the CPU and RAM out of the motherboard I've got in favour of an upgrade.
I've had a look around an it looks like the best components I could get into that board are the Athlon 7850 black edition @ 2.8 GHz and some of the faster DDR2 2x4GB modules. Correct me if I'm wrong please.
or,
I could replace the lot and go for something like a socket AM3 with DDR3 Ram. If this is the only way to go, please give me an idea of a minimum spec to go with.
Out of the 3 options what would lead me to the best value for performance?
Thanks very much for any comments, info and help.
Its a real Dinobot!
or,
