Okay my second computer needs upgrading. The spec is as follows:
AMD Athlon X2 6000+ 3.0Ghz AM2
4GB DDR2 RAM 667Mhz
AM2 2000Mhz FSB mobo
ATi 512Mb 5850 graphics card
Creative X-Fi platinum soundcard
700W modular PSU
I want to get a similar spec to my main machine(sig)
I'm thinking of getting
Intel i7 950 1366 socket
motherboard that has triple channel DDR3, preferbly crossfire and at least 1 PCI slot that wont be covered up if i had crossfire as i may add another 5850 later(for soundcard) and if possible, USB3 but not an absolute must
6GB Triple channel 1600Mhz RAM or more
My budget is £450, i could go up to around £500 at a push. I've got a bonus from work coming and well, computer needs upgrading
Thanks
4GB DDR2 RAM 667Mhz
700W modular PSU
Thanks
i assumed the i7 was the high end faster CPU = better for gaming and i thought i3/i5/i7 sockets supported triple channel depending on particular mobo
May be able to get a SSD on top with the above
