Hi.
My current setup is as follows;
- AMD Phenom II X3 Tri Core 720 2.8GHz @ 3.5GHz (Socket AM3) - Retail
- Gigabyte GA-MA790XT-UD4P (Socket AM3) PCI-Express DDR3 Motherboard
- Corsair XMS3 4GB (2x2GB) DDR3 10666C9 1333MHz TwinX Dual Channel (TW3X4G1333C9) [TW3X4G1333C9]
- HIS 6870 1GB Gfx card
- Seagate Barracuda 7200.12 500GB SATA-II x2 (in Raid 0)
- Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) [HD103SJ]
- Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter
- OCZ ModXStream Pro 500w Silent SLI Ready ATX2 Modular Power Supply
- Arctic Cooling Freezer 64 Pro PWM CPU Cooler
All I use the computer for is gaming, and I have a budget of around £400. There is a little room for movement if it's worth it, but I will quite happily spend less if it's not needed.
Thanks in advance, Cas.
) and I think the CPU seems to be holding me back a little, I can't get the kind of frame rate at the kind of quality I'd like. Which I'm assuming is my gfx card being held up by the CPU?
