Spec me an upgrade please
21 Jul 2008
Earth
After having Ghosts crap out on me because I haven't got enough ram, and now Wolfenstein not working due to still running vista, and a few other newer games performing not at their best, and the fact I built this PC in 2008 I think I'm due an upgrade, and will probabley turn my current one into a HTPC.
What would people recommend for about £1k-1.2k, to hopefully get me another 6 years.
Will be recycling my case, blu-ray drive, HDD's, and if I can I have a Coolermaster 850w modular PSU which I would like to reuse if possible.
So all I'm really after is;
- Motherboard
- CPU
- CPU Cooler
- RAM
- Graphics
- OS
Normal resolution I use is 1920x1080p, and have went with AMD graphics for a while now, but may fancy a change to Nvidia.
Cheers
YOUR BASKET
1 x MSI Geforce GTX 780 Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card £347.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £251.99
1 x Gigabyte Z97X-Gaming 3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Antec Kúhler H2O 1220 Series 4 High Performance Liquid CPU Cooler £81.6
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (TXD38G2400HC10QDC01) £59.99
Total : £926.54 (includes shipping : ).
What is your current case ?
The Gaming 3 board comes with a free headset whilst stock lasts
If you can hang fire a few weeks, the refresh 'k' cpu's should be out.
We need to know what case you have, so we can recommend a cooler that will fit and to make sure the new Gpu will also fit.
The Antec 300 is a pretty old design now. The Antec 1220 wont fit in the roof as the case only has 1 fan mount.
Are you open to a new case as well ?
Yeah i would stick with the 780. You can always upgrade the gpu when it starts to struggle, or go sli with another 780.
