- 18 Oct 2012
Hi guys, i'm thinking i might take the plunge and upgrade, the old 8150 is now poorly matched to the rest of my setup and is showing it's age.
So, i'm looking to switch sides, and i'm currently debating between skylake and haswell e.
What i want;
16gb of ddr4 memory, nice n fast (dual channel for skylake, can be quad for haswell if theres a benefit to that)
An asus motherboard (as a reference if i was buying skylake it'd be the maximus hero, not top end but pretty good)
Apart from that cpu i'm not sure which would be better, i'm thinking haswell is the smart option even if it is pricier, also if anyone could let me know if my current alpenfohn k2 will be a straight fit (ie i dont need to get a new cooler) it'd be very helpful.
Budget is dependant, ideally i want the maximum price/performance ratio as opposed to pure cost, but its just cpu mobo and ram i'm changing so i cant see it being too bad.
What i want;
