Spec me - around 450ish!
26 Oct 2004
Near Brighton
Hey all!
Im looking to build a new rig soon - I already have a monitor, keyboard, speakers and my 2 hard drives so basically just need the main rig minus the hard drives.
Budget 450ish (less if possible) and would preferably want it for media and gaming really.
Thanks all, much appreciated :)
Chris
edit - would want a new case too btw!
Something like this would give you the basis of a decent system and it is well under budget so more Ram or aftermarket cooling is definitely an option.
Gigabyte GA-P31-DS3L Intel P31 (Socket 775) PCI-Express DDR2 Motherboard £44.99
(£52.86) £44.99
(£52.86)
Intel Core 2 Duo E2200 "LGA775 Conroe" 2.20GHz (800FSB) - Retail £48.99
(£57.56) £48.99
(£57.56)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £22.99
(£27.01) £22.99
(£27.01)
Sony NEC Optiarc AD-7200S 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £13.99
(£16.44) £13.99
(£16.44)
Leadtek GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £124.99
(£146.86) £124.99
(£146.86)
Antec NSK 6580 Super Midi Tower Case - 430W Earth Watts PSU £57.99
(£68.14) £57.99
(£68.14)
Sub Total : £313.94
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £10.95
VAT is being charged at 17.5% VAT : £56.86
Total : £381.75
Cheers for that :) appreciate it! Will have a look into it - maybe upgrade a couple of things to the next level as it seems i could spend a bit more!
