Spec me basic components for a new system
10 Jul 2010
Carrying on from my old thread, here.
My current E8400 installed onto an Asus P5Q Pro motherboard with 4GB of ram is starting to what I feel hinder me, in terms of performance. Lack of SATA 3 for my SSD and lack of USB 3 are my biggest issues.
I do tinker with virtual machines and I feel I could benefit from more RAM. 8GB would be much better, in that it would allow me to allocate 2GB for a VM and a GB or two for cache to save hammering the SSD. 16GB would be very nice, but I think the extra 8GB would only end up being used as cache in all honesty. Speaking of memory, I'd like the memory to be nipping due to the use of caching for the SSD.
My GTX 660 is perfectly adequate for my current needs, therefore I'm not buying one for a long time.
My primary concern is over power consumption. My power meter says that my base unit is pulling around 70w at the plug. I fully expect this to fall with a new system - not by much, but I'm hoping to see about 60w at idle. Although a quad core CPU might be nice, I'm concerned about the impact it might have on power consumption.
I'd prefer the new motherboard to be an Asus brand, with USB 3 and onboard gigabit network - this will get rid of my PCIe cards. A single PCI slot is a must for my soundcard - I don't mind being more than one, but I doubt I'll use more than one.
I'd like the motherboard to provide me with the ability to undervolt (yes, UNDER) my CPU just as I have with my E8400. I'm not looking to overclock, just as my E8400 hasn't been overclocked, apart from once to see it's potential.
I'm going to say my budget is, at an absolute maximum, £350. From that budget, I'm looking for a motherboard, CPU, RAM and a cooler.
I'm looking at socket 1150 Asus motherboards with the Z97 chipset. What would the Z97 give me that the Z87 wouldn't?
Intel i5 processors look reasonably priced. The i3's seem like'd be okay for a budget system, but an i5 would feel far more comfortable when gaming. The i7 are just out of question. :D
What LED and minimal difference in performance with tighter timings .
When I was looking for RAM with tighter timings, some had LEDs.
As for timings, I feel I'll benefit from tighter timings when using VM. Especially if I'm running two at the same time, or decide to use a cache for one VM.
In terms of CPU coolers, how does the Raijintek Aidos fair, particulary with noise? For a little more money, can you get a decent, quiet HSF like the Arctic 7 Freezer?
I'm leaning towards this now:-
Product Name Qty Price Line Total
Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail £125.99
(£104.99) £125.99
(£104.99)
Asus Z97-K Intel Z97 (Socket 1150) DDR3 ATX Motherboard Asus Z97-K Intel Z97 (Socket 1150) DDR3 ATX Motherboard £89.99
(£74.99) £89.99
(£74.99)
TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLYD38G1600HC9DC01) TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLYD38G1600HC9DC01) £61.99
(£51.66) £61.99
(£51.66)
Raijintek Aidos Direct Contact CPU Cooler - Black Raijintek Aidos Direct Contact CPU Cooler - Black £14.99
(£12.49) £14.99
(£12.49)
Sub Total : £244.13
Shipping :
VAT is being charged at 20.00% VAT : £48.83
Total : £292.96
TDP is the heat output I think, not power usage.
Spend a fiver more and get the Themis cooler, same with RAM and spend £4 more and get the 2133mhz set :)
A few reviews mention that the Themis is quite big, therefore some motherboards might be incompatible. Is there an equal, more compatible cooler, even if I had to spend a little more?
Hmm, I have one - it's really not big at all. What kind of incompatibilities? RAM clearance? You might be looking at Themis Evo reviews
But I'd have to up my FSB to get those speeds. I'm not planning on overclocking, just as I've had no real need to overlock my E8400. That's what I why I was focussing on memory timings.
Fair enough, I think its always great to have a fall back :P, you will get the bug once.
@darael you don't oc through the fsb/bclk on those boards/cpu's its a fixed bclk and all overclocking is done through the cpu multi (the chip you want to go with will have a locked multi)
and you can pick set ram speeds from a dropdown list in the bios so 1600/1800/1866/2100/2400mhz ect
you can run 2400mhz with stock cpu clocks
EDIT: you can also go h97 chipset if you wanted to save a bit more and not overclock the cpu,ram will be limited to 1600mhz though I think on those chipsets
