Spec me (big build)
19 Feb 2009
Hey guys,
Roughly four years ago now i asked for help on a build in which you guys were fantastic and help so much i thought i'd ask for help again.
I'm looking to build a new rig from scratch and possibly sell on the bit's i already use now to make extra money for this rig.
The Rig and what i want
I'm currently looking to build a new RIG, I've currently got £2,500 as my Budget. I don't really want to go any higher than that if possible.
I'm looking for three monitor build, in which they don't have sides so they sort of fit right next to each other with no gap between(If possible). I'd like to have water cooling this time around as I've never tried that and it should be fun to set up. I'm also looking to OC this Rig, That's pretty much why i want water cooling in there, it also looks awesome too.
I haven't really got anything in mind what i would say i most definitely want, but I've seen a case that i like would like to get unless there's a better option http://forums.overclockers.co.uk/showthread.php?t=18527343
If any one could help out, that would be fantastic as i'm slightly out of tune with all the new stuff as my last build was four years ago. the build doesn't need to include Mouse keyboard as i'll just use my what i use now.
Many thanks.
EDIT: finished my spec now:
YOUR BASKET
1 x HIS HD 7990 6144MB GDDR5 PCI-Express Graphics Card £479.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £259.99
3 x Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black £164.99 (£494.97)
1 x XSPC Razor HD 7990 VGA Waterblock £149.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £143.99
1 x MSI Z87-G45 Gaming Series Intel Z87 (Socket 1150) DDR3 ATX Motherboard £124.99
1 x Antec High Current Gamer 850W Modular '80 Plus Bronze' Power Supply (0-761345-06225-1) £119.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £114.95
1 x XSPC D5 Dual Bay Reservoir/Pump Combo V2 £109.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x Patriot Venom Red 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV38G240C0KRD) £65.99
1 x XSPC RayStorm CPU WaterBlock (Intel) £51.98
1 x XSPC EX360 120mm Radiator - Black £49.99
1 x XSPC EX240 120mm Radiator - Black £41.99
1 x BitFenix Alchemy Premium Modding LED Strip - Aqua Red 50cm £29.99
3 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £25.99 (£77.97)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
1 x Mayhems X1 UV Red Premixed Watercooling Fluid 1L £7.99
2 x BitFenix Alchemy 8pin PCI-E extension 45cm - Red £6.98 (£13.96)
2 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear/UV £6.49 (£12.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
10 x XSPC G1/4" to 3/8" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£29.90)
Total : £2,498.18 (includes shipping : £22.20).
The fans are for the Rads (single sided) and a spare for the back :)
Cheers Doom, that shall give me a base line.
Any idea's on three monitors that would fit very nicely along side each other?
Na worries, ive finished my spec now so have a good look over it, it should be great. :)
I think those super thin bezel monitors will look great in eyefinity. You could attempt to remove the bezel like some have but i wouldn't suggest it. :)
So i've had a look at the end build and was thinking of taking out the PSU as i'll just use the 850w i already use. I'd possibly go to 2x 8gig ram so i'm on 16, as i do host a few servers for a few of us to play on, extra memory can't hurt? and i'm thinking of removing the Seagate Barracuda 2TB, i can use the one i already have for now.
I'm also thinking as i get paid in two weeks to possibly go to a £3,000 build, as i'll be selling my other parts to make extra for this, so possibly another 7990?
I think this is a first ..... TTL said it couldn't be done but here goes nothing ........
black and gold :D
YOUR BASKET
2 x EVGA GeForce GTX 780 Classified 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-3788-KR) £599.99 (£1,199.98)
1 x Iiyama Prolite G2773HS 120Hz 27" Widescreen LED 1MS Monitor - Black £329.99
1 x Seasonic X-Series 1250w '80 Plus Gold' Modular Power Supply £219.95
1 x Corsair Graphite 600TM Midi Tower Mesh Windowed Case - Black £145.99
1 x Asus Z87-PLUS Intel Z87 (Socket 1150) DDR3 ATX Motherboard £143.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x Asus Xonar D2X 7.1 PCI-E Sound Card £89.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99
2 x Avexir Gold Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CEY) - Yellow/Gold Light £71.99 (£143.98)
5 x Alpenföhn 120mm Wing Boost Pure Plus PWM - Black £9.95 (£49.75)
2 x Akasa "Vegas" White LED strip light - 60cm £8.99 (£17.98)
1 x BitFenix 24-Pin ATX Extension 30cm - sleeved gold/black £7.99
2 x BitFenix 8-Pin PCIe Extension 45cm - sleeved gold/black £6.98 (£13.96)
1 x BitFenix Alchemy Molex to 4 x SATA power extension - Black £6.98
2 x BitFenix 6-Pin PCIe Extension 45cm - sleeved gold/black £6.49 (£12.98)
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Black £5.99 (£11.98)
1 x BitFenix 8-Pin EPS12V Extension 45cm - sleeved gold/black £4.99
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Black £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Black £4.49
Total : £2,973.96 (includes shipping : £27.55).
or with the 3 monitors ......
YOUR BASKET
3 x Iiyama Prolite G2773HS 120Hz 27" Widescreen LED 1MS Monitor - Black £329.99 (£989.97)
2 x EVGA GeForce GTX 770 SC ACX Dual Bios 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2776-KR) £329.99 (£659.98)
Total : £3,016.79 (includes shipping : £38.25).
