Well, its time for an upgrade for the festive period and Im looking to upgrade my current system (A64 3200+ S754, 1gb DDR, 9800Pro). Im looking to go C2D
A few questions first though.... I do plan on overclocking the system, as people seem to be getting real nice results, but I wont be going for every last Mhz I can get, so absolute latest / greatest stuff isnt needed. With that in mind, is the extra £20(ish) for the E6400 worth it over the E6300 to get the higher multiplier? or will I get more than enough of an OC from the E6300?
Also, I have an Enermax 480w ATX2.0 PSU, will this run the system ok (im not thinking dual GTX's or anything here, just a Single PCI-E card like a 1950pro or similar) will I need any kind of adapter to connect to the newer (ATX 2.2) boards?
With all that considered, Can someone spec me for:
(My Budget is probly around £400-£450 (maybe £500 at a squeeze, if the performance increase was really worth the extra)
C2D CPU (E6300 or E6400, depending on peoples opinions)
Motherboard (Again, depends on peoples opinions, but most people seem to like the P5b(?) or the DS3/DS4 (whats the difference?)
Ram (2GB would be nice, with overclocking potential, I see lots of people saying Geil or Crucial PC6400 2gb kits i think?)
GFX Card (Well, my current is a 9800 pro, so anything is gonna look fast, but I dont wanna spend an absolute fortune, so perhaps something that is mid-range but clocks very well)
Thanks all.
Thanks all.
- Its much better than the XFX 7600 XXX, uses less power aswell
