Spec me CPU/Mobo
16 Apr 2007
So my motherboard died at weekend.
Rest of spec is
256GB SSD + few HDDs.
650Watt Corsair PSU
Gigabyte 7970 OC.
Windows 8.1.
8GB DDR3 I cant remember what type but Im sure its just 1333mhz stuff.
Coming from a 1055T 95Watt. Will be reusing my freezer 7 pro.
I am thinking 4670k with something like the Z97 Gaming 5 but there are so many variations Im unsure whether its worth the extra.
System used for mostly gaming and I will be OC'ing the CPU if I can.
Any ideas guys? Id like change from £300
Basically, get what you were looking at... cannot go wrong...but the cooler is a little weedy for the processor
If you like your AMD look at the MSI Gaming 970 and an 8350/20... you will save money and put the money towards a better cooler
might be, but the color doesn't exactly match MB, which is why I went with above. There are plenty other coolers too.
Don't worry...there's no right or wrong when it comes to recommendations...all are possible choices with its own merits which OP could considering ;)
At the end of the day, it's down to OP do decide what he wants for himself :)
