Spec me! :D a case to fit in my TV stand
18 Mar 2012
Eastbourne
Hello all,
My biggest hate when building a PC is picking cases, trawling through finding something for it not to meet my spec.
So this is where you amazing people come in!
I need an ATX case that is 130x500mm. To fit in this bottom hole and replace the HP. I don’t know if this is even possible with a full height GPU as I don’t have one to hand.
Thanks :D
Atx makes it big. Which means cooling around the box is restricted. You may be able to look at something like a rack mount case as the cooling flows front to rear so it can use all the space without needing to vent to the sides.
3u rack height is about 135mm
2u rack about 90mm
2u rack about 90mm
This is what I was thinking, I’ll probably just design something and print it.
Hello all,
Thanks :D
Thermaltake core g3 if you can find one.
