spec me ddr3,x48,best mobo
11 Mar 2008
im wanting to buy the best there is mobo that will support ddr3 and a qx9650,and 2x hd3870x2,also need to be good overclocker,any price range.:confused:
Only really one choice atm that is xfire compatible AND ddr3 and thats the Asus P5E3 Premium unless you like gigabyte boards then go for the DQ6 x48.
Why do you want an X48 motherboard if you already have the Asus Maximus Extreme? They are just speed-binned X38 chips anyway, there's next to no difference between them.
