Spec me extractor fans
1 Apr 2014
Aberdeen
I have two internal (no outside windows) bathrooms in my house with Expelair Premier fans which are very noisy. So I want to replace them.
The first bathroom is a standard 6' square bathroom.
The second bathroom is rather larger and I was using as a store room having removed the impedimenta and merged it with the room where the hot water tank used to be. The fan has been remounted on a false wall which covers the holes for the toilet, sink & shower. I have just had electricity run there and want to turn it into a utility room. It will likely contain a fridge, some computer equipment, and maybe a washer / dryer. So I'm going to need an extractor fan that can be on 24/7. It also needs to be quiet as it is right next to my bedroom.
The vents behind the extractor fans are top left and about 80mm in diameter.
