Hello!
Current setup:
GPU: MSI R7970, possbly going to get Crossfire this afternoon.
CPU: i5 2550-K
Case: Silverstone FT-01
I'm toying with the idea of watercooling my PC for both GPU and CPU, and have looked at the following:
EK Water Blocks EK-FC7970/R9 280X CSQ £67.99
XSPC X2O 750 Dual Bayres/Pump (Black) V4 £59.98
EK Water Blocks EK-Supremacy Clean CSQ - Nickel £52.99
Magicool Copper Radiator - 180mm £47.99
EK-EKoolants UV Green EK-EKoolants UV Green £5.99
2x Primochill Primoflex Advanced Tubing 13/10 - Clear £11.98
Total : £246.91
Due to the case having 180mm fans, I was hoping to use a 180mm rad and connect it to the front bottom fan as I have removed all the 3.5" drive bays (http://www.silverstonetek.com/images/memo/FT01Remark-01.jpg) and there is plenty of room for the rad there.
I was going to have a res and pump combo in the 5.25" drive bays.
I am unsure of what fittings to use - can anyone recommend any improvements or alternatives to the above or suggest good fittings please?
Thank you!
Current setup:
CPU: i5 2550-K
Total : £246.91
Thank you!
