Spec me - Fluid, Pump bracket & tips
27 Mar 2013
Nottingham
After having everything I need to build my hardline loop for months now, I've finally decided to use up all the bits.
Only bits left that i need are fluid; either clear or pink is mayhems still generally the go to?
and a bracket to mount my EK x-res Revo 140 pwm preferably to a 120mm fan slot on my rad.
Two thing i want to double check tho. I have a 360 nexxxos monsta, a double thick 240mm XSPC and a 120m black ice nemisis. I dont really want to use the 240 so will the monsta and black ice be enough for a 6700k and 980ti?
and finally I can't for the life of me remember the trick to get my pump to run at full rpm when filling the loop. It is the weird model that when plugged in would not run at full rpm without PWM signal.
