Been running a Dell Studio 1737 which has served me well, even on the gaming side but its dead and I'm using my mothers crusty old laptop.
Can anyone spec me a laptop that is/has:
Thin (ultrabook would be nice)
Backlit keyboard
2.5" internal drive
Preferably Haswell due to the increase in battery life and the iGPU
Obviously good Battery life.
15+" screen
Will only be using it to surf the web and work. If it can, then a bit of Sony Vegas work and light 2D work in After effects.
Thanks for any suggestions. Model numbers are fine, doesn't have to be from OCUK!
Backlit keyboard
2.5" internal drive
15+" screen
