Spec me Haf 939 replacement
13 Jun 2011
Need a case to replace my quite frankly huge haf 932, am bored with this case now an fancy a change.
Case will need to fit as follows
Gigabyte z77x-d3h
3770k watercooled
7970 xfire -watercooled
1x 360 rad with 3 fans
1x 240 rad with. 2 fans
Dual bay res
Seasonic x series 1050w
Had to bodge my 932 around quite a bit to get the 240 in the front, would like to be able to fit both rads without too much bodging, removable hd cages for example would be nice!
Would also like if possible the case to have native ssd mounts and to be one colour inside and out, one of my gripes with the 939 is the silver interior
Budget is prob a max of £150
Steve
Do you mean the Haf 932?
Sounds like the new Corsair 750D would be right up your street.
Could be the 932 will check when i get home :)
Was actually just looking at the 750d looks like a nice case!
I have a 932 and looking at your pic it looks like one!
The 750D was going to be an automatic choice for me until I found out you can't put a 240mm radiator on the bottom (I need the two drive cages). Poor design choice from Corsair, or maybe they didn't want people to have that capability, who knows.
Have you thought about the NZXT Switch 810, Kelt?
