I've been after these tools for a while and finally have the cash. I figured i would get the opinions of the
GD masses before i buy as they are not cheap.
Budget £1200 for both.
Mill Usage: Wood, Plastic (such as Delrin), Aluminium.
Lathe Usage: Wood, Plastic (such as Delrin), Aluminium and possibly steel.
Will be using them for making components/adapters for cameras/telescopes/mounts. Possibly some rc stuff as well.
The ones i am looking at are:
Lathe £634.94: http://www.axminster.co.uk/axminster-sieg-sc2-300mm-mini-lathe-prod809904/
Mill £666.95: http://www.axminster.co.uk/axminster-sieg-sx2-mini-mill-prod809899/
Axminster do those 2 in a bundle for £150 off.
Bundle £1149: http://www.axminster.co.uk/axminste...d-sieg-sx2-mini-mill-Package-deal-prod885357/
I was also looking at a lathe from Warco but they never seem to be in.
Lathe £499: http://www.warco.co.uk/metal-lathes-metalworking-lathe-machine/302922-mini--hobby-lathe.html
Also some from Amdeal but the site seems a bit broken. When i go to checkout to see postage costs it always
hangs.
Lathe £420: http://www.amadeal.co.uk/acatalog/Mini-Lathe.html
Mill £470: http://www.amadeal.co.uk/acatalog/XJ12-300.html
I also have about £100 - £150 separate for tools and materials.
I will probably get plastics from: http://www.plasticstockist.com/Default.aspx
And aluminium from: http://www.aluminiumwarehouse.co.uk/
Any help will be greatly appreciated.
Thanks.
hangs.
Thanks.
