spec me - itx - £400 ish
I will be needing a you, not the case tho as I have already ordered it l, I saw it and loved it lol, im also going itx as there smaller and I don't have much room l,
Also I'll be using it for gaming, mainly for guild wars 2 and maybe a couple old rts games
Was thinking abit cheaper on the psu tho as I've seen this just didn't know of it would fit
http://www.overclockers.co.uk/showproduct.php?prodid=CA-230-CM
Also thanks for the help :)
Its a shocking PSU. And its a ITX case you need a modular PSU in that. Unfortunately ITX builds are always more expensive.
That's looks good to me, think I may wait till payday and buy the parts then,
Is there any way I can save that basket to my own ?
Thanks for all the help.
Also on the last list would that motherboard support a i3 CPU ?
ok so this is what i got so far,
same as above minus a couple parts and diff CPU
YOUR BASKET
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
1 x Asus P8H77-I Intel H77 (Socket 1155) DDR3 MiniITX Motherboard £83.99
1 x Toshiba (7K1000.D) 500GB SATA 6GB/s 32MB Cache - OEM (DT01ACA050) £49.99
1 x OcUK Value 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £26.99
Total : £262.36 (includes shipping : £9.50).
im looking to see if you guys can help me find a GPU for less than £100 as my budget is getting tighter and tighter.
Thanks
ZeRo
Forgot to mention, ive ordered the case (bitfenix prodigy) and PSU (https://www.overclockers.co.uk/showproduct.php?prodid=CA-167-CM)
