Spec me memory please
7 Nov 2009
my mobo is a Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
current memory is Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Low Latency Tri-Channel
I would like to upgrade to 12GB, could someone spec me the correct RAM or best way to upgrade, thanks :)
i have the same memory and board and it works very well together
as suggested i would get another 3x2gb of the corsair memory
I couldnt find the exact same memory type as the one I have. Does it matter which type of corsair as long as its 3x2 DDR3?
