Spec me - Micro ATX PC
Man of Honour
20 Sep 2006
Hi all,
I'm looking for the following:
  • Smallest possible case
  • AMD or Intel - more than 4 cores, preferably 8
  • 32GB RAM support minimum, 64GB+ would be ideal. Basically 4 DIMM slots
  • Must support m2 and SATA
  • Not essential, but dual NIC would be great. Think 10Gbit is a bit far away from regular home stuff yet
  • Cheap as possible
Clock for clock performance is not massively important, but RAM and number of CPU cores is. It needs to be as cheap as possible and run cool.
If you haven't guessed already, I'm looking at using it as a hypervisor, preferably VMware. I realise a NUC would be ideal for this but I really want more than 2 cores with HT and the 32GB RAM limit isn't ideal.
Drives can be configured after.
Hi all,
  • Cheap as possible
intel based, dual Ethernet, 32gb ram, small form factor and i7 8700 non K 6/12 core/threads
My basket at Overclockers UK:
Total: £877.00 (includes shipping: £11.10)
if your wanting higher DIMM support, then stepping up to mATX format but size increases
Total: £895.64 (includes shipping: £11.70)​
sure others can spec ryzen but running 32gb and 64gb comes a challenge​
Looks like you can get a gen 8 NUC now with quad core and HT. I'm wondering if I can get a better spec for less money or if I should just get a NUC.
8th gen is hex cores- intel do this a lot with NUC- changes numbers and some clock speeds and list it as latest - but depends on what chipset its based off for functions .
im sure 6 core NUC will come out soon
specially now AMD are doing embedded systems
http://linuxgizmos.com/files/amd_v1000_models.jpg
guessing will be a lot cheaper
