Spec me mini atx 1080x1920 Capable (Cheap)
29 Aug 2003
West Midlands
Looking to build a mini atx 1080x1920 Capable (Cheap)
Would like to go along the mini ITX lines for portability.
I'm going to be putting one together myself from ocuk but thought I'd start the thread off as I've never done a Mini ATX and hopefully get some of advice and opinions.
HDMI should be fine to use for 1080p :)
This will be bought tomorrow!
I'll update the post with my setup shortly
idea would be £250 (not sure if possible)
max of £500 would like to keep it cheap
We have a monitor, keyboard, mouse and the OS
We don't have any old parts for use in this build
The other thing to specify is what you need/don't need - namely
Monitor
Operating System
Keyboard/Mouse
And normally specify if you have any other re-usable items (PSU/case/HDD/optical drive being common ones) but it sounds like you don't have those.
So wait, you want it to be able to run 1920x1080 but you won't be gaming on it at all?
no games at all its more about the HD aspect of it with the use of graphics.
feel free to prove to me that I won't need it but this is what I've been asked for.
Are you using software that takes advantage of GPU's, because otherwise, there isn't much point going for a trinity CPU. You could do quite well with a Pentium and an SSD instead.
YOUR BASKET
1 x Silverstone Sugo SG05 HTPC USB 3.0 Case with 300W Power Supply - Black (SST-SG05B USB 3.0) £86.99
1 x Corsair Force Series 3 120GB SATA 2.5" 6Gb/s Solid State Drive (CSSD-F120GB3A-B) £78.98
1 x Gigabyte H61N-D2V Intel H61 (Socket 1155) DDR3 Mini ITX Motherboard £40.99
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £35.99
1 x Intel Celeron G550 2.60GHz Socket LGA 1155 Processor - Retail £31.99
Total : £288.44 (includes shipping : £11.25).
Or swap the SSD for a normal HDD.
If you need HDMI, go for this board instead:
YOUR BASKET
1 x MSI H61I-E35 Intel H61 (Socket 1155) DDR3 ITX Motherboard £49.99
Total : £297.44 (includes shipping : £11.25).
no movies it'll be displaying HD graphics done in house
Never even crossed my mind to use an ssd good call :) and will be needing a HDMI so thats looking top notch right now. with the case replaced for a cheaper one
Don't forget that that case includes a PSU, so it works out quite cheap. Also it is incredibly portable.
ah that makes sence now. think i my change the ssd for a hdd as I don't think the performance will change that much for what we are using it for.
Your Basket
Seagate Barracuda ... 1
ASRock H61M-ITX In... 1
In-Win BM639 Mini ... 1
TeamGroup Elite 8G... 1
Intel Celeron G530... 1
Subtotal £247.94
£206.62 ex VAT
