Spec me - Mobo + CPU
13 May 2004
Wales, Wrexham
Replacing my DFI Lan party mobo (supposedly broken atm) and my 3500+ AMD64
What upgrade would you advise me to get, X2 processers worth it?
(needs to be PCI-E Mobo)
Edit - Looking to spend around £300 ish, or less if the extra spent is hardly worth it
Okay so for £50 over you could get:
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£109.95 £109.95
MB-061-GI Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
£89.95 £89.95
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£107.95 £107.95
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.95 £14.95
Subtotal £322.80
VAT £56.49
Total £379.29
Or this:
MB-144-AS Asus M2N-SLi Deluxe (Socket AM2) PCI-Express DDR2 Motherboard (MB-144-AS)
£89.95 £89.95
CP-166-AM AMD Athlon 64 X2 Dual Core 3800+ 2.00GHz (Socket AM2) - Retail (CP-166-AM)
£89.95 £89.95
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£99.95 £99.95
Subtotal £279.85
VAT £48.98
Total £328.83
Or if you wanted to keep your RAM and be under budget:
CP-127-AM AMD Athlon 64 X2 Dual Core 4400+ (Socket 939) - Retail (ADA4400CDBOX) (CP-127-AM)
£149.95 £149.95
MB-111-AS Asus A8N-SLi Premium nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-111-AS)
£85.95 £85.95
Subtotal £235.90
VAT £41.29
Total £277.19
EDIT: I know the top one is way over but I'd forgotten a heatsink :o However it will offer excellent overclocking potential and I *think* will reach E6600 speeds :cool:
I have 2gb Geil value already, so ill be keeping that ram, and i wont be overclocking them - still my best options for gaming?
£109.95 £109.95
£89.95 £89.95
£107.95 £107.95
£14.95 £14.95
Subtotal £322.80
VAT £56.49
Total £379.29
Or this:
£89.95 £89.95
£89.95 £89.95
£99.95 £99.95
Subtotal £279.85
VAT £48.98
Total £328.83
£149.95 £149.95
£85.95 £85.95
Subtotal £235.90
VAT £41.29
Total £277.19
well obviously the most appealing option out these three would be conroe. but if your not inclined to do abit of overclocking then i dont think it would really be worth getting conroe. and would go for the 4400+x2 instead. although conroe would be more future proof if u were to go with socket 939
Ok here goes, im going to spend more than i planned (Makes a change)
How about an E6600 and the gigabyte board you mentioned with a decent heatsink? :P or do i need a certain speed of ram?
No, the RAM is very good, especially at that price :cool: If you're going to be spending a bit more then it may be worth getting a better cooler :) Also, what PSU do you have?
Seasonic S12 600W - Ok, what cooler then? -
E6600 + Gigabyte G1 Turbo + ? (Hell, if youe going to do it i might as well do it right :P)
i was thinking Thermaltake Sonic Tower 4-in-1 Noiseless Heatpipe (Socket 939/754/775/478) CPU Cooler (CL-P0071) (HS-009-TT)
with a 120mm fan on it that i have on my xp-90 now?
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN) 1
£214.95 £214.95
MB-055-GI Gigabyte G1-Turbo G1975X Intel 975X (Socket LGA775) PCI-Express Motherboard (MB-055-GI) 1
£124.95 £124.95
HS-009-TT Thermaltake Sonic Tower 4-in-1 Noiseless Heatpipe (Socket 939/754/775/478) CPU Cooler (CL-P0071) (HS-009-TT) 1
£19.95 £19.95
Subtotal £359.85
VAT £62.98
Total £422.83
Should i press Buy? :P
To be honest, I would stick with the DS3 as it seems pretty good value for money and people have had very good overclocking results with them. The cooler, I'm not sure on- the thermaltakes always used to be very good on S939 and S754 but I've not heard much about them on S775 but anything will be better than the stock cooler I guess. Just looking at that cooler though, I would make sure it fits your case first and even then I'm not sure how good it is :)
Just to clarify, the RAM you have in your current A64 system will be DDR. So if you are planning to go intel core2duo or AMD sktAM2 you will need to budget for DDR2 RAM, as your current DDR would not work
Oh yeah, never noticed you didn't have any RAM in your spec. I wondered how he'd managed to get an E6600 and a much more expensive motherboard for only a bit more than my spec :o
Ok i ordered it anyway, the XP-90 is massive too, just not as tall, but it will fit in my case.
So my old system
S12 Seasonic 600w
DFI-U Lan Party Mobo
3500+ AMD64 (Newcastle)
7800GTX EE
2GB GeiL value
To
E6600 Conroe
G1-Turbo (probalby should have done what you said.. but im an idiot)
7800GTX EE still
2gb GeiL value still
So, will i notice much of a difference? Cant see any bottlenecks as such, maybe the value ram / graphics card, im not sure :D
Hmm, I'd try and phone OcUK to try and get the order changed to the DS3 and add the RAM on otherwise you'll pay postage twice. Won't make the RAM so expensive either that way :) Or just see if you can scrap it and go with my original Conroe spec :cool:
