Spec me mobo, ram, gfx and cpu
smr
smr
6 Mar 2008
Leicestershire
Hi,
A customer of mine has asked me to get him some quotes on these parts to fit into his existing case.
He wants to future proof the system for at least two years and didn't give me a budget but said that he didn't mind spending a bit but didn't want to spend silly money so I would say he's looking for mid-range hardware etc.
I am tasked with the job of putting it altogether, he may or may not need a new case but from what I remember it was quite spacey inside anyway so as long as the graphics card isn't gigantic then it shouldn't be a problem..
There's no preference as to whether the system needs to be Intel or AMD neither, although I think he will primarily be using it for gaming, which can be taken into consideration.
A few quotes would be nice, ie. cheaper to a tad more expensive stuff.
Thanks for any help ;)
