- 11 Sep 2013
I'm in need of a monocular, but I've no idea what brands are good these days.
I have some little Miranda 8x22 binos from the early 90s, but they were cheap even back then and are now knackered.
This will be used out on hikes and the like, to find landmarks, spot birds and animals, maybe some static tripod use, etc. Will be stowed in a pocket or pouch, so needs to be fairly small, no spotting scopes or anything like that. Will occasionally be used by young children, so needs to be fairly robust and/or cheap enough (maybe £50-100) to replace if they break it.
- Small enough for a pocket or webbing pouch.
- Relavtively robust, but cheap enough to replace if it gets too dinged up.
- Decent magnification. Somewhere between 10x and 20x, ideally with a zoom feature.
- Lens caps front and rear, included or available separately.
- Standard size camera/tripod mount socket.
- Lanyard point.
What do people suggest?
- Lanyard point.
