Caporegime
- 7 Apr 2008
- Lorville - Hurston
Hi all, I am looking to have a go at setting up a water cooling system to cool down my pc. I have been fascinated with the whole idea but always bailed out as I was very worried about reliability issues and costs.
Costs is fine now as I am more mature and have a decent job And in terms of reliability issues, as long as I do it “right” it wont leak.
Now the purpose of WC is because of my 480gtx. Its loud when fan is at 70-80% and very hot. I feel that WC is a great way to cool it down and to do some OC on. I would also like to do some OC on my cpu. Get up to 4.5ghz at least while keeping temps down.
So with the reasons out of the way, below is my current spec pc:
• ASUS P6T deluxe Socket 1336 Mobo
• 6GB DDR3 Ram
• Nvidia 480GTX card
• Intel i7 920 2.6GHZ Nehalem
• Corsair Moduled 800W PSU
• Lian LI full tower PC-A7010 case
• Thermalright Ultra Extreme aka TRUE
I have done some reading on WC and this is what I have learned so far. What I need is this:
• Radiator
• Reserviour(What is this used for?)
• Pump
• Hoses
• CPU and GPU blocks
• Fittings/clamps
Here are a few questions:
What is the reservoir used for?
Once all hooked up, How do I drain and change the water later down the line and how often do I need to drain and maintain it?
Once all is hooked up, do I do this?
1. Add 1 litre of water in reservoir
2. Turn only the WC kit on and not the pc
3. Put tissues around the Water blocks on my gpu and cpu to test for leaks
4. Leave it on for 10-24 hours on
5. If no leaks after 10-24hours, Turn the pc on and enjoy nice cool temps and high overclocks.
What kind of liquid do I use? Bottled distilled water from supermarket?
I heard I should not mix coil with another material? Do I need to make sure all the pumps, rads, fittings/clamps, reservoir, etc are all one material?
Now my last question is where I can purchase this: http://www.lian-li.com/v2/en/product/product06.php?pr_index=305&cl_index=2&sc_index=45&ss_index=74 I have literally looked everywhere, even on eBay. Closest I found was a silver one from k*** pc.
Now what’s my budget? my budget is £300-£320 for the full whack.
Are these temps doable on my budget:
4.5ghz at 60c MAX load
Stock 480gtx speed at 40-50c MAX load(Leaving plenty of room to OC it).
Thanks all and looking forward to your thoughts and opinions. I am a complete noob on this so apologize for some questions i have asked.
edit: has to be upgradeable so i can easy remove my 480gtx and slap on a new card when i buy one next year
• 6GB DDR3 Ram
• Radiator
• Pump
• Hoses
• Fittings/clamps
Think i am ready for a spec!
