- 14 Dec 2005
- Bath
I’m after a NAS for home. Currently I’m being a ***** and just using a couple of RAID1 Caviar Blacks in one of the PCs. I would like a proper NAS now, not a PC acting as a NAS (noise, size, power consumption).
The main purposes of the NAS will be:
However... lots of people say that it (well the Drobo range in general) is “overpriced and slow”.
The Drobo uses some proprietary BeyondRAID system. I don’t give a **** what they call it, how it works, and whether it’s proprietary or not. What I do like however is that you can mix and match disk sizes, replace disks on the fly (pull out a 500GB and replace it with a 1TB) and expand the array on the fly. No copying of the data to elsewhere or anything, just shove in some more disks or replace current ones with bigger ones and the Drobo will sort everything out (obviously only one at a time – allowing it to automatically move the data around before replacing the next). This is good. If only it wasn't “slow”.
Soo… what NAS should I buy that does the same as the Drobo and is not “slow”? I'm not biased brand wise, Netgear, Synology, Drobo, whoever!
- Serving ~30GB MKVs to the HTPC – I like to straight rip blu-rays, not compress them down or anything.
- Generic filestore for all Macs/PCs. RAW photos from the DSLR, ISOs/installers for purchased software, etc.
- Time Machine for the Macs.
