Spec me Please :)
10 Apr 2006
Leicester
Hi there, im looking to upgrade before I go back to uni and therefore I need a nwe computer. I am on a computing course, and therefore will need to use the computer for programming, video editing, music editing, and some gaming (mainly ut2004, but also new games), (max settings not important but would be nice if I could!)
I dont need k/b, mouse or monitor or speakers, i just basically need
processor (conroe/am2 (if its any good?))
mobo
gfx card
case (quiet if poss)
a power supply
hdd (pref 250gb SATA)
hopefully I would like to keep it under £600 if possible :confused: ??
thanks to anyone who will spec me and any comments suggestions welcome :D
TIA
Kiran
what about RAM? a typo perhaps?
Processor I would suggest conroe over AM2
Mobo: asus or gigabyte with the conroe...
Gfx : possibly a 7600gt
case: lian li pc7+ or antec slk3000b (best bet is asking in case thread) i think the latter case comes with a psu..
hdd : seagate or samsung
hows that sound?
if you really wanna go AM2 then we can go into more details with parts etc same with conroe..
yeah RAM too - my bad :)
Yeah i would really prefer conroe if the budget allows it as i know they are very good.....
To be honest no, because I'm not too confident in that department plus I don't really have the time/patience :)
MB-063-GI Gigabyte GA_965P_S3 (Socket 775) PCI-Express DDR2 Motherboard (MB-063-GI)
£79.99 £79.99
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£124.95 £124.95
CA-048-AN Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (CA-048-AN)
£54.95 £54.95
GX-025-BG BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-025-BG)
£74.95 £74.95
HD-082-SE Seagate Barracuda 7200.10 320GB ST3320620A ATA-100 16MB Cache - OEM (HD-082-SE)
£54.95 £54.95
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£115.99 £115.99
Subtotal £505.78
VAT £88.52
Total £594.30
conroe option will do you an AM2 one as well if u want?
£79.99 £79.99
£124.95 £124.95
£54.95 £54.95
£74.95 £74.95
£54.95 £54.95
£115.99 £115.99
Subtotal £505.78
VAT £88.52
Total £594.30
ONLY thing I'd change with that is go for a DG3/DG4 motherboard, unless its just too much for you to streach that little bit more. well worth it.
