Spec me please.
30 Dec 2005
Can you please do me a spec for a Core duo 2 machine.
My budget is 550 (ill go above if you really think it could make a difference)
I use internet, office, photoshop. 3D RENDERING (IMPORTANT). A few games. And i encode a lot of videos.
I like to have lots open at a time, so it needs to be a good multi tasker,
and its needs to be pretty upgradable.
Thanks. (btw just the system, no monitor etc :D)
EDIT : Oh, i forgot to say a couple of things, i will definitely be overclocking, and i need a case and psu in that price :P, thanks again.
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£107.99 £107.99
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£139.99 £139.99
GX-025-BG BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-025-BG)
£74.99 £74.99
HS-003-SY Scythe Ninja Plus Rev.B Heatpipe CPU Cooler (478/754/939/940/AM2/LGA755) (HS-003-SY)
£29.99 £29.99
HD-085-SE Seagate Barracuda 7200.10 200GB ST3200820AS SATA-II 8MB Cache - OEM (HD-085-SE)
£45.95 £45.95
CA-048-AN Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (CA-048-AN)
£54.99 £54.99
CD-041-NE NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-041-NE)
£18.95 £18.95
Subtotal £472.85
VAT £82.75
Total £555.60
Sorry forgot motherboard :(
£107.99 £107.99
£139.99 £139.99
£74.99 £74.99
£29.99 £29.99
£45.95 £45.95
£54.99 £54.99
£18.95 £18.95
Subtotal £472.85
VAT £82.75
Total £555.60
Another £50 gets you an X1800XT well worth it.
except there is no mother board in that spec ;) give me a sec, i'll do 1
£107.99 £107.99
£139.99 £139.99
£74.99 £74.99
HS-020-ZA Zalman CNPS9500-AT Aero Flower (Socket 775) CPU Cooler (HS-020-ZA)
£29.99 £29.99
HD-093-SE Seagate Barracuda 7200.9 160GB ST3160811AS SATA-II 8MB Cache - OEM (HD-093-SE)
£34.95 £34.95
£54.99 £54.99
CD-054-SO Sony AW-G170AB2 18x DVD±RW x12 Ram Dual Layer DVD-Writer - (Black) OEM (CD-054-SO)
£18.95 £18.95
MB-063-GI Gigabyte GA_965P_S3 (Socket 775) PCI-Express DDR2 Motherboard (MB-063-GI)
£79.99 £79.99
Subtotal £541.84
VAT £94.83
Total £636.67
it is a lot over yor budget, but for what you want it about fits, my spec is about £100 more, but it has a mobo :D
just a few preference changes, zalman cooler for your CPU...i like zalman, and a sony DVD drive...same price, just a better brand :rolleyes:
lol.
Thanks for your help guys. I think ill get that spec, and i might pay the extra for the X1800XT.
I think ill buy that lot, and then ill ugrade a bit more when i have the money. Maybe get a raptor? would it make much of a difference?
Oh, and i got a question about RAM mhz, what is the highest you can get at the moment? and will having only 800mhz max on my motheroard hold me back when i want to upgrade?
Oh and i dont have a clue about ram timings either, so can you explain that aswell lol.
Thanks :P
can you get over a 1000 yet. I heard it being talked about a while ago. But im not sure whether they are out yet
£107.99 £107.99
£139.99 £139.99
£74.99 £74.99
£29.99 £29.99
£34.95 £34.95
£54.99 £54.99
£18.95 £18.95
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
£129.99 £129.99
subtotal £591.84
Total: £695.41
I think im gunna go for this. I need wireless, and this motherboard has it and will be better anyway. If im wrong please tell me :P
mobo change looks fine, and it used to say under the allendale that reports from toms hardware of an overclock of 2.4mhz...correct me if im wrong anyone...and the zalman should be able to handle the heat fairly well
