spec me please.
2 Feb 2006
Need to make a new PC for next door, they have £300 to spend no more!
Will just be used for internet and word processing, maybe the odd game for the kids (wouldn't be much as there only about 7years old!)
need every thing apart from monitor, mouse and keyboard as they can come from the old pc.
I was thinking Amd 2.5Ghz socket 939?, 1Gb of ram? and 200 - 250 hard drive?
What you all think? some quick specs would be great thanks.
How about this? Good performance for a budget setup - great for desktop usage and very light gaming.
Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU £59.99
(£70.49) £59.99
(£70.49)
Samsung SH-183LBEBN 18x18 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black) - OEM £17.99
(£21.14) £17.99
(£21.14)
Samsung SpinPoint T HD160HJ 160GB SATA-II 8MB Cache - OEM £34.99
(£41.11) £34.99
(£41.11)
Asus GeForce EN7300GS-HTD 256MB DDR2 TV-Out/DVI (PCI-Express) - Retail £35.99
(£42.29) £35.99
(£42.29)
Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB) (VS1GBKIT667D2) £34.99
(£41.11) £34.99
(£41.11)
AMD Athlon 64 X2 Dual Core 3800+ 2.00GHz (Socket AM2) - Retail £47.99
(£56.39) £47.99
(£56.39)
Asrock AM2NF3-VSTA (Socket AM2) AGP DDR2 Motherboard £31.99
(£37.59) £31.99
(£37.59)
Shipping : £9.95
Total : £321.81
Was tryin to look for that case but couldnt see it, then I just looked up the model number you gave and its silver - I was sure it was black!! So no wonder I couldnt find it. I would go with that case to save a tenner and less watts on the PSU. 450W would be un-needed.
will this all work? still a bit over 300, but got a bigger hard drive.
