Spec me please!
12 Sep 2012
I would like to build my first gaming desktop around a budget of 600-700 including Monitor and everything. I will also be using Photoshop on this machine. Any suggestions? :confused:
Nice spec above but I don't like the case although that's personal preference. However I'm sure I'm not the only one who likes a case with cable routing holes, what's the point of having one without any with a modular PSU? Whole point of a modular is better cable management :p
I would snap up this bargain
http://www.overclockers.co.uk/showproduct.php?prodid=CA-031-XG
Not to sure why you stuck you tongue out, but as the OCZ ZT is fully modular the OP only needs to attach the cables he uses and thus there wont be anything to hide away as it will all be in use or left in the PSU box.
If you look here even a install can be made to look neat.
Also the Silverstone case uses a internal USB3.0 connector, the other doesn't.
