Spec me please.
19 Aug 2009
Cornwall
Im looking at building a new computer as my main one is nearly 4 years old. Although it has served me well. The upgrade bug is itching ;) Im looking at future proofing this as well. Main use would be gaming at 1080P but may upgrade the monitor later
I have about £1000 (but any less would be a bonus)
This will be for the main system
CPU
Ram
new case A full tower (obviously personal preference say £120)
Motherboard
Psu
and water cooler heat-sink
I have a 64GB SSD, multiple hard drives, Bluray drive and OS (from this comp)
I also have a GTX 480 which i will stick in for the time being and upgrade it the month after.
Any help apreaciated :)
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £199.99
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £112.99
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM3) (CW-9060014-WW) £94.99
1 x XFX Pro Series 750W XXX Edition Modular '80 Plus Bronze' Power Supply £84.98
1 x BitFenix Shinobi USB3.0 Gaming Windowed Case - Black £59.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £41.99
Total : £609.94 (includes shipping : £12.50).
H110 is the same as the H100i, just using 140mm fans, obviously the RAD is bigger to compensate for this.
The motherboard is a great all round, but not worth getting if your not looking to SLI. THIS would be the one to get if SLI/xFire is not what your looking at.
The PSU will cope with SLI/xFire just fine, again 550 will be fine if your not looking to SLI/xFire.
Case is great, they are really well recommended. You could also look at Corsair & CoolerMaster.
Thanks mate thats much cheaper than i thought. Its not really worth going i7 still for gaming is it?
Will defo be looking at SLI
If you are only gaming, the only difference is hyper-threading. While currently there are no games which will utilise this feature, there is no guarantee it wont change for future releases.
