spec me please
14 Apr 2010
swanley,kent
1 GX-30Q-EA EVGA GeForce GTX 1050Ti Gaming 4096MB GDDR5 PCI-Express Graphics Card £149.99 £149.99
1 CP-62F-IN Intel Core i7-7700K 4.2GHz (Kaby Lake) Socket LGA1151 Processor - Retail £349.99 £349.99
1 HS-035-CM Cooler Master Hyper 212 Evo CPU Cooler £26.99 £26.99
1 MY-48N-CS Corsair Dominator Platinum 16GB (2x8GB) DDR4 PC4-21300C14 2666MHz Dual Channel Kit - Black (CMD16GX4 £149.99 £149.99
1 MB-676-AS Asus H110-Plus Intel H110 (Socket 1151) DDR4 ATX Motherboard £59.99 £59.99
1 SW-172-MS Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139) £94.99 £94.99
1 HD-373-SE Seagate Firecuda SSHD 1TB 5400 RPM 2.5" Laptop/PC/PS4/PS4 Pro Upgrade (ST1000LX015) £68.99 £68.99
1 CD-069-AS Asus 24x DVD±RW DRW-24D5MT SATA ReWriter - Black (OEM) £13.99 £13.99
1 HD-366-WD WD Blue 1TB 7200rpm SATA 6Gb/s 64MB Cache HDD - OEM (WD10EZEX) £48.95 £48.95
1 CA-004-SF Super Flower Golden Green HX 650W "80 Plus Gold" Power Supply - Black £79.99 £79.99
£1043.86
okay mate has asked for a price for the above. he needs a pc for motion graphics, animation 2d and 3d modelling.
can you spec me a better pc than the above please for around £1000/£1200
For starts you have specified an overclockers processor (K variant) but a non/mild overclocking motherboard. It would work but would be a waste!
As is the RAM, too expensive and for overclocking. Would ditch the SSHD too and replace with an SSD.
And would that cut it well for what he needs? Won't need a cade as I have a decent one he can have. Is the Haswell better than the one I put in?
It should cut it, the haswell has more cores than the 7700K 6 vs 4 (12 vs 8 threads), the motherboard is a bit wider than standard ATX, does your case accept eATX?
I also think SSHDs suck, either get a normal HDD or get a proper SSD.
Gigabyte X99 SOC Champion Intel X99 (Socket 2011) DDR4 EATX Motherboard Stock Code MB-520-GI
8 In stock
Was: £224.99 £164.99*
£164.99*
Intel i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K) Stock Code CP-546-IN
4 In stock
£398.99*
£398.99*
Team Group Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16Q Stock Code MY-058-TG
20+ In stock
£79.99*
£79.99*
Samsung 250GB 750 EVO SSD 2.5" SATA 6Gbps Solid State Drive Stock Code HD-224-SA
20+ In stock
£98.99*
£98.99*
Seagate BarraCuda 3TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST3000DM008 ) Stock Code HD-36L-SE
19 In stock
£92.99*
£92.99*
Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139) Stock Code SW-172-MS
20+ In stock
£94.99*
£94.99*
Super Flower Platinum King 650W 80 Plus Platinum Power Supply - Black Stock Code CA-057-SF
20+ In stock
Was: £87.95 £67.99*
£67.99*
**B Grade** Sapphire Radeon RX 480 Nitro+ 4096MB GDDR5 PCI-Express RGB Graphics Card Stock Code BG-14C-SP
3 In stock
Was: £209.99 £169.99*
£169.99*
Alpenfohn Ben Nevis CPU Cooler - 120mm Stock Code HS-048-AL
6 In stock
£21.95*
£21.95*
Delivery cost calculation
1. Country Destination
2. Payment method
3. Shipping type
Delivery information
Dispatches: Monday to Saturday
Arrives: Next working day
Goods total
Delivery costs
Total order value
Total value excluding VAT
Total VAT at 20.00 %
£1,190.87*
£11.70*
£1,202.57
£1,002.14
£200.43
Youve picked Win10 on disk rather than the USB stick option, thus meaning you would need a DVD drive.
Your last spec looks good. The only thing I would say is that with that spec you're already using all available RAM slots, and with the kind of suggested use for that machine it might be a good idea to just get 32GB DDR4-2400 from the start.
You might also have issues actually finding a 5820K, but the 6800K is more widely available and is about £30 more (maybe less).
The i7 5820K is readily available.
