Spec me PSU for haswell
23 Mar 2011
Devon
hi all,
just about to order my latest upgrades.
im running, a WC loop with 1 pump, 2 HDD's and an SSD, haswell i5 and a 6870.
have no interest in Crossfire either
case is an NZXT phantom
so could someone spec me a PSU :)
looking to spend at max £80~
thanks
will they work with haswell?
i was under the impression only certain PSU's were compatible?
Yes they work, the "Haswell compatible" thing is a bit of "much a do about nothing" and involves some older PSU's not being able to supply a new low voltage required for one of Haswells power saving sleep states.
These sleep states can easily be turned off in the BIOS.
ok thanks :)
is there any benefit for getting the Antec over the seasonic and vice versa?
I wonder how much the PSU companies paid Intel to put that in just so we all got rid of perfectly good PSU's.
(perhaps a little cynical)
