Hi folks, long time lurker, but a bit out of touch having not built a system for years.
Little confused over compatibility with mATX boards, cases and GPU options in terms of room available for a given case etc. Would like to keep budget around £7-800 but I'm flexible. - Not sure how much I can re-use, if anything!
Will be a general use machine, but I'd like it fast, pretty quiet and able to handle gaming without too much stress.
Current spec (Keeping dispays and peripherals):
Case: Thermaltake Tsunami
PSU: Corsair HX620
Mobo: ASUS P5K-E
CPU: Q6600 G0
Cooler: Zalman CNPS
RAM: Corsair Dominator 8500C5D
GPU: MSI GTX460 3GB
HDD: 2 x WD Caviar SATA3 in RAID
I'd like something along the lines of an I7, at least 16GB memory as I'll be running VM environments sometimes, SSD for system and platters for storage, interested in liquid cooling, but might be too ambitious!
Any help gratefully received...
Cheers
PSU: Corsair HX620
Mobo: ASUS P5K-E
CPU: Q6600 G0
Cooler: Zalman CNPS
GPU: MSI GTX460 3GB
Cheers
