Spec me RAM and Graphics for under £80 please?
6 Dec 2008
Hi Guys,
I have recently purchased HP ProLiant MicroServer N40L.
The main purpose for this is to stream and play my media library across the house, i.e. mp3's,avi's,mkv's. I would like to run XBMC media player on this server and play everything from here.
I’m guessing to play mkv's I will need a graphics card and 2GB just seems a little under powered as my laptop has more RAM!
Obviously any help would be most appreciated as I’m a n00b too all this server configuration setup malarkey.
Thanks in advance
Jack
Below is the Spec of the server:
Product Description
HP ProLiant MicroServer - Turion II Neo N40L 1.5 GHz
Type
Server
Form Factor
Ultra micro tower
Dimensions (WxDxH)
21 cm x 26 cm x 26.7 cm
Weight
6 kg
Localisation
Europe
Server Scalability
1-way
Processor
1 x AMD Turion II Neo N40L / 1.5 GHz ( Dual-Core )
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB ( 2 x 1 MB )
RAM
2 GB (installed) / 8 GB (max) - DDR3 SDRAM - ECC - 800 MHz - PC3-10600
Storage Controller
Serial ATA ( Serial ATA-300 )
Hard Drive
1 x 250 GB - standard - Serial ATA-300
Monitor
None.
Graphics Controller
Shared Video Memory (UMA)
Networking
Network adapter - PCI Express x1 - Ethernet, Fast Ethernet, Gigabit Ethernet
Power
AC 120/230 V ( 50/60 Hz )
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
Manufacturer Warranty
1 year warranty
