Spec me some 120mm ARGB fans for radiators with controller that perform and look good....
22 Aug 2010
On the Wagon-East Angular
Allo - not sure if this is the right section, but it'll be a start! I'm planning a new build and would like to get some decent 120mm fans. The case will have a minimum of 6 (2x3) and a maximum of 9 (3x3) 120mm fans, along with an ARGB waterblock, initially a Sapphire RX 6600 XT that has an ARGB logo and I've since fitted some ARGB fans too - this will be vertically mounted, but when I upgrade the GPU it will also be watercooled, probably with an ARGB block, initially the loop only has static lighting, but I may, or may not use a distroplate. I've not ruled out additional case lighting or maybe strimmer cables......
My system currently uses a Razor Chroma Controller, this works well, but only has 6 outputs so will not be much use in my new setup.
So - fans/argb controller hub type things - what's good? Ideally I'd like to be able to control each item, so a minimum of 9 but preferably more controllable outlets, along with fans that look good and perform well with radiators. I've looked at the Lian Li UNI AL120 and UNI SL120 fans, but don't know how many additional items the controller can control, and how well it plays with non Lian Li items. Appreciate any thoughts - TIA
