Spec me some deodorant...
22 Sep 2008
Kent, England
Spec me some antiperspirant...
Erm, bit of a strange question, but nevertheless, does anyone have any recommendations of a good antiperspirant to use? Preferably after something that actually prevents/absorbs perspiration, and not something with a really strong smell.
Currently using Adidas, but seems a bit useless. Any ideas?
I've used the Adidas stuff before and found it lacking. I use Lynx now and it does the job perfectly for me. They also had a guy employed on the design team to make it sound better when it was sprayed! :D
Heh, thinking about I'm not sure if there was a scientific reason behind it or it was an internet urban legend. I remember a while back there was a bit of a hoohar as they use aluminium particles to block your sweat pores which isn't a good idea. I'm not sure if that's the same now.
Ah right, not heard about that.
My thought too.
I shower daily and am a clean person, but I perspire lots and get sweat patches if I don't use 24 hour protection stuff. I don't smell at all, but it's horrible to be sweating lots and have sweat patches.
It could be that you have hyperhidrosis. I remember one guy on TV sweat a lot under his arms and so he had the sweat glands sucked out or something along those lines.
Sure. Big cans, lasts a long time, stops sweaty pits! Never had any complaints! If I'm goin out though, I have a can of Armani for man that I use ;)
I always thought anti-perspirent was just a form of spray on talcum powder, which absorbs the sweat, not prevent it :confused:
