- 25 Nov 2009
Hi guys,
I'm an amateur detailer at best and as such I have just 'got by' with the following...
Wash:
Lambswool mit
2 buckets
Dodo Juice Sour Power or AG Body Shampoo
BH Regular Clay
Polish/minor correction:
AG SRP Or Megs #83
Collinite 476s
along with an array of microfibres and waffle weave towels.
Wheels are taken care of with Valet pro's Bilberry Cleaner.
My new car is an Electric Blue Mini Cooper S visually identical to this
It has the usual swirls and stonechips etc but my aim is to clean up what I have, I'm in the market for a good usable hand polish with fillers like the SRP but I like to try new products. Also I want a nice glaze/sealer that will sit well under a few coats of Collinite 476. I need something for the tyres and plastics too, not too glossy but a good sheen would be sweet!
Overall durability is key, hence why I'm such a fan of the 476
What might you recommend? I'm thinking along the lines of Chemical Guys Glosswork Glaze and Poorboys Natural Cleaner.
Much appreciated.
Wash:
Lambswool mit
2 buckets
BH Regular Clay
AG SRP Or Megs #83
Collinite 476s
Much appreciated.
