- 20 Feb 2009
- Ashton-Under-Lyne
Ok, so just got my car, so in need of some advice on the essentials to have around (and which models etc).
Main 2 I've thought of are wind screen scraper & tyre inflater (with pressure gauge), are there other essentials similar to this I haven't thought of?
For the scraper, I was just going to see what Tesco have the next time I'm there, as I imagine there's no real difference between any of them, and I can't imagine them being much more expensive than anywhere else.
The tyre inflater though is causing me problems, there are so many to choose from with so many different features. Obviously I don't want to spend a ridiculous amount on one, but I also don't want it to fall apart after using it a few times.
Are there any specific models that are recommended to last/stay away from? Same with features, is there anything any of you have that you feel you just couldn't do without, or thought you would use, but don't?
