Spec me some fans please
18 Oct 2002
EGBB
Looking for some quiet fans for my Tsunami Dream case. I need 2x120 fans and 1x90mm fan (for the side). Its got thermaltake in there at the moment which are very noisy. Spec as in sig. The Phantom is super quiet so quietness is the key to these fans I am after please.
the side fan will most likely be 92mm ;) no one makes 90mm :)
+1 for the akasa apaches, just got two my self, awesome fans, very quiet and shift tonnes of air :D
If huge volumes of air are not required the Fractal Design fans are effectively silent. I run three and can't hear them even at full pelt.
I don't need huge airflow just silence with some airflow moving the hot air out of the case. It probably is a 92 mm fan actually lol. Thanks for the tips guys will look into some Fractal Design.
