Using a true 120 inside a cosmos s, at the minute im using a scythe s-flex and the drone of it is getting pretty annoying. Im wanting to set up a push\pull system but with fans that aren't as noticable. Any suggestions?
Ive got some sharkoons and to be honest i dunno how they got the name "silent eagle" as theyre very noticable. I think ive a pair of yate loons on my old rad, might give them a try.
There are at least 3 different types of Sharkoon fans and the low speed ones are fairly quiet, as are Scythes, Noctuas and the low airflow versions on Yate Loons.
I like the Arctic Cooling AC12025PWM fans as they actually stop completely in low load situations but they are quite loud under load. The only way you will get real silence is to remove the fans altogether.
I'd consider fans from the new manufacturer GELID - their new 'Wing' range of fans are exceptional. OCUK only stock one of their CPU coolers unfortunately.
Great back pressure, very quiet running and can run at 5v easily - REVIEW HERE
Another good alternative - and what i use in my own case at present is the Sharkoon Silent Eagle 1000rpm.
