Spec me some fans!
17 Sep 2010
Wolverhampton
Hi Guys,
Currently got a CM Scout case and look to replace all the fans!
I need 2 x 140mm Fans
4x 120mm Fans
I would like the to be quiet but i do want good airflow :D 2 of the 120mm fans are going on my H50.
Like the look of the Scythe kama 2 but not seen them anywhere yet. Thanks Stulid for the links was going to get a couple of fans on that test that were not impressive in the testing.
Scythe Gentle Typhoon 1850rpm. Best fans i've ever owned.
Get a fan controller though as they don't have PWM
The Akasa Viper is also nice, but it's too loud at full RPM
The Scythe pushes more air and is much quieter
Thermalright ty-14's have one on my archon incredible fans I'd get in quick because they seem to sell fast when they appear in stock
and for 120mm i'd go with silverstone air penetrators personally for case
and the two for the H50 I would get as fast and strong as you can as you can always turn them down when needed and up when stress testing etc.
(sorry if hijacking) Im thinking of using CM Sickleflow fans on the inside of my ATCS 840 when i get it back from powdercoating i.e. 1 on exhaust and 2 at the HD cage. Do you think they will be suitable as in noise / airflow for the job?
Also can you reccomend some PWM fans to go on my cooler pls I was thinking about Apaches or Alpenföhn Föhn 120 Wing Boost until I saw the charts above.
Thanks guys
I'm using Apaches, very good airflow/noise, I would recommend those.
I also bought a couple of 120mm Air Penetrator fans which, while quiet at full pelt, do not have as high air flow as Apaches and have an audible whine which doesn't disappear until you're down to around 1200 RPM. BUt I have sensitive hearing.
