I HAD A FEW DELTAs - YOU HAVE TO SHOUT A BIT![]()
how thick are the dlets? will i be able to mount onto my rad using a normal size screws for like a normal 120mm fan?
these deltas are to sit on my black ice 480 extreme!
noise isnt what i *** but comes with the package!
But you haven't answered my question? What makes you think you need 4 x 200 cfm fans?
You might drop temps by a degree but is it worth it to have four jet engines running next to you?
