Spec me some LED
27 Mar 2016
Bristolian living in Swindon
Hi all
Looking to light up my case with some smart LED lights, Not looking to spend a lot just some basic lighting but easy to fit.
Ive not installed LED's before, I have a Gigabyte AB350-N ITX motherboard is there a connection on there that i just plug it into?
Thanks
I'd like to know this too.
My mobo has one 3 pin LED header (switchable 5v/12v) - I'd like to put some UV leds on this head. It has two 4 pin RGB headers - I'd like to put some RGB's on those. The only thing the manual says is to use 5050 leds. th e3 pin header can support 300 leds / 5m and the RGB headers can support 120 leds / 2m.
