Spec me some memory for X99
18 Oct 2002
Kent
It looks like I may have managed to get myself a 3070ti and it looks like I might need to upgrade my CPU (5820k) and RAM (its 2133mhz).
I was hoping someone might be able to spec me 32gb of RAM that I can use now in my X99 system that I will be able to reuse in a year or so when I upgrade to a more modern CPU and motherboard.
Thanks
More modern might mean you're onto DDR5 though... which X99 is not.
In my experience, Corsair Vengeance works very nicely on X99.
Crucial Ballistix does too but be aware that, if you get any with RGB, their MOD utility does not work on X99 - You may be able to use the mobo Mfr's own, but it's a dice roll. Mine works fine with Asus Aura and runs at (IIRC) 3600MHz, so I'm very happy.
