Spec me some new bike gear!
13 Jan 2009
Finally got round to buying a bike for a 7 mile commute. Have a locker/shower at work, so quite happy to get some decent cycling gear. Will be my first bike in quite sometime, so want to get used to a bike with cleats before committing to the commute.
Have quite a few questions... so feel free to comment on anything I might have missed out!
Clothing - Any brands to go for/avoid -heard mixed things on Rapha. Was thinking a base layer and a jersey. Should I consider a soft/hard shell jacket?
Maintenance - Any kits/tools worth purchasing?
Was also looking potentially getting a cycle computer (Wahoo ELEMNT bolt). Would be cool to have gps/track my rides.
Any feedback is appreciated!
Be good to mention a budget for everything as things can soon start adding up and it's good to keep control of it or at least be aware. You'll soon be buying the odd bit here and the odd bit there in the future too most likely.
For this time of year I'd recommend a good jersey/jackey to keep you warm and as comfortable as possible. The Castelli Gabba / Perfetto jacket is a well recommended jersey which is warm and waterproof. Don't have one myself as I picked up some Sportful Castelli's sister company) jerseys last year in the sale at Cycle Republic.
A base layer I use Nike Pro base layers that I had previously from running and have found no issue.
I'd also be looking at getting a pair of bib shorts as well but I can't really recommend any as I just use cheap planetx ones at the moment and whilst they do the job I'm sure there is something much better out there to be honest.
I'm sure the others will be around shortly to recommend on maintence and the cycle computer.
I've heard @Roady has quite the extensive tool kit :p:D
This jacket is a softshell and is reduced in the sale to £55 from £110 and if you order a few other things then you can sign up for £15 off £100 spend too.
https://www.cyclerepublic.com/clothing/jackets-gilets/sportful-giro-soft-shell-cycling-jacket.html
This jacket is one that I actually have myself although I did pay £65 for it last year. It's £90 now but I love this jacket. Really good in the wind and it's water resistant so good for the odd mild shower but it will still get soaked if it's peeing it down. I can wear this when it's really cold with just a base layer underneath with a summer jersey and I'm fine. Good for autumn too with just a base layer.
https://www.cyclerepublic.com/cloth...tful-fiandre-light-windproof-jacket-aw17.html
Personally I'd recommend a Merino base layer, and then something like the Rapha winter jacket.
It's the most expensive option, but I really do think it's worth the money.
Maybe also check out vulpine, they have 30% off everything at the moment, and also make good quality stuff.
Thanks for the advice. There is Rapha store close to work.
Will definitely look into merino base layers.
Is there any maintenance I should be looking to do after each ride?
Torm do good jerseys in a similar vein to Rapha (for similar read: Rapha nearly sued them) for a fraction of the price. They've not got as wide a range, and the quality isn't right up there with Rapha but it's hard to argue given the price.
The Wahoo Elemnt Bolt is a brilliant cycle computer. I've been using mine for 6 months or so and it's excellent.
For commuting you want to be able and prepared to ride in any and all weathers, so I'd recommend mudguards if your bike will take them. Get decent warm gloves. Get neoprene overshoes but don't spend a fortune on them as they will tear up over time.
Always carry at least one spare inner tube with you, along with some means of inflating it, be it CO2 cylinders or a pump, or ideally a pump that doubles as a CO2 inflator. I also take puncture patches with me in case I'm having a really bad day... Take a multi-tool. I use the Topeak Hexus II.
Update
Thanks for all the replies. Visited all the local cycle shops (Evans, Rapha, Cycle Surgery etc). Decided to go with a Rapha Winter Jacket (30% off), Merino base layers and la passione bib shorts (again in their sales).
Will look to expand the wardrobe over the year, but has been exciting to get on the bike!
Good choice on kit so far, with the Rapha store so near make the most of it, the vast majority of their kit for 'regular' sized cyclists is pretty much the pinnacle of comfort, features and quality. I had a weak moment back in the summer (birthday!) and bought some of their Core bib shorts (£75) and a pair of their Pro Lightweight shorts (£175) in a deal. I returned the Pro as the Core are such good quality with a fantastic strap and pad design they're the best fitting shorts I've ever worn. Until now I've not grabbed any more (they're £100 normally) but as soon as there's another sale I'll buy another pair (or two).
Most of the rest of my kit is Sportful and Castelli, the Fiandre range from Sportful I've found fantastic for UK spring/autumn riding. My go to commuting shorts during the cooler weather are Sportful Fiandre NoRain and I'll wear them October-April. During the winter I'll wear a pair of thermal padless tights over the top, current ones are DHB. Jerseys tend to be Castelli but most of my thicker thermal jerseys are Sportful (R&D Long Sleeve Wind are superb) with a DHB ASV Windslam for the worst of the weather (I've had ice form on the outside of it when riding). I've tended to go this route rather than with jackets as I prefer the closer fit and will layer up underneath, I wear a gilet almost all weathers. I can ride a wider range of temperatures by managing my own layers and wearing the same jersey/outer layer this way. I've found windproofing almost more important than thermal (because I have good base layers). DHB is certainly worth a shout for commuting gear, excellent value and quality, but the fit and sizing can be a fiddle to get right. I used to wear mostly DHB but as I've sized down have replaced it with more expensive. The only way I've been able to fill my wardrobe with sportful & castelli kit is by buying clever, waiting for deals and buying winter kit in the summer etc etc. Hope that helps! :)
Totally missed this before lol :D
I did start out buying complete kits, thinking I needed EVERYTHING and then carrying much of it with me. I now carry far less and my advice would be to research more about which specific tools you need and then buy the quality value ones of them. Park tool are expensive, but some of their range is easily affordable if you buy specifics. My toolbox has a lower layer of tools from kits I bought and have never/barely used, while breaking/wearing out the ones I needed as they where cheap.
Thanks for the advice...now looking for some cycling shoes.
Was thinking m540 pedals, any recommendations on shoe brands?
Depends on budget really. For instance I got a pair of Fizik R1Bs for just over £140 as they are end of line which is a bargain but they are a road shoe not MTB, it also depends if you are definately going for the m540 pedals as that dictates the type of shoe you are going to go for
Pretty flexible on both pedals and shoes.
A chap at work mentioned the MTB fitting is quite good for clipping on and off (London commuting). As it will be my first clipless pedal I'm open to suggestions.
Budget wise happy to spend up to 200. But would prefer to keep it cheaper if possible!
I only just started clipping in a few weeks ago (new to road biking, and rode flats on the mtb for years). I went with road type pedals, and it's a doddle to unclip. I've heard that about mtb pedals too, but the road ones are a doddle really.
Well MTB cleats are metal and are recessed so they are easy to walk on without wearing out the cleat. Road cleats are larger, made of plastic and sit proud, so if you walk on them a lot then they wear out. Both are easy to get in and out of but MTB pedals are usually dual sided so that makes things easier.
Road pedals generally have a larger foot/pedal interface which some say increases power transfer compared to MTB pedals, I cant say I could tell the difference power wise and I have both and a power meter. Best thing is to decide which system you would prefer and go from there but from my experience Sidi and Fizik make fantastic shoes
Update.
Decided to go with m540 peddles and Giro Privateer shoes. Went with the size 10 (EUR 45), however it is a little tight. Do these shoes have any give over time? Or is it best to order the next size up?
Update.
What material are they? If the uppers are synthetic then they probably won't stretch.
I'm coming to the party late and it might be pointless, but Endura for me make some of the best fit stuff out there for the money. It's not cheap, but not Rapha expensive and it's so damn comfy and well made. (I have 4 pairs of bib shorts, 2 longs, winter jackets, base layers etc. from endura)
Not having much luck with these Giro Privateers. The next size up was far too big, so will return to wiggle.
Any decent cycling shops in London with a large variety of shoes? The cycle surgery and Evans near me have a very small range.
