I'm planning a few overseas trips in the next 6 months and I really need to be thinking about getting some appropriate gear. Mainly I need the following:
1) Tripod
I presently use a fairly big tripod with an Arca Swiss ball head but this is going to be far to big to travel with. I want something that is lightweight yet strong, not too bothered about price but if it's expensive then I want it to be justified.
2) A backpack/bag
I presently use a Tamrac Expedition 7 which is a little to big to travel with as carry on bags. I'm still deciding on gear that I will take but as most will be landscape'ish I'm thinking D800, 14-24mm, 24-70mm and a 70-200 with a 2x converter. I may have to change this I guess subject to weight.
So what do you recommend for the above? also what other bits should I be thinking of getting?? The trip I'm most looking forward to will be Iceland in March next year but still in the planning stage for that one.
1) Tripod
2) A backpack/bag
